A/C compressor runs with heater on
2016 JEEP WRANGLER
50,000 MILES • 3.6L • 6 CYL • 4WD • AUTOMATIC
  • 15 POSTS
My A/C compressor runs with the heat on in all modes, when it is raining. Other than that it only runs in defrost, like it should.
Dec 10, 2019 at 11:25 AM
Good afternoon,
Do you have automatic climate control or manual control AC?
The automatic will always activate the AC compressor for humidity control.
The manual should only work on defrost mode.
Dec 10, 2019 at 12:52 PM
  • 15 POSTS
Not automatic, manual control.
Dec 10, 2019 at 1:50 PM
Okay, there is a module under the hood called a totally integrated power module. It controls all body functions including the AC controls. The control head you use to command sends a signal to this module and based on that input, it turns the compressor on and off.
This module is a common failure. With the age of your Jeep, I would question if it is covered under warranty.
Dec 10, 2019 at 2:10 PM
  • 15 POSTS
Hi Roy,
That module was already replaced, it was covered under warranty, do to the parking lights not shutting off.
Thank you
Dec 10, 2019 at 2:32 PM
You need to have that rechecked to see if it has the proper programming in it. The wrong program will cause this.
Dec 10, 2019 at 2:33 PM
  • 15 POSTS
Okay, thanks .
Dec 10, 2019 at 2:37 PM
You are welcome.
Looks like it may be programmed for the automatic climate control system.
Dec 10, 2019 at 2:49 PM
  • 15 POSTS
Okay. Thanks a lot for the info!
Dec 10, 2019 at 4:35 PM
  • 15 POSTS
Come to think of it, I didn't have this issue until it was replaced. Thanks again!
Dec 10, 2019 at 4:36 PM
You are welcome.
Dec 10, 2019 at 4:44 PM
