Recently the A/C in my car stopped working where it was only producing hot air even on the lowest setting. I then realized that this was either the result of the A/C needing to be recharged which I did and unfortunately to no effect or the A/C compressor was malfunctioning. I then went to replace my A/C compressor, then noticed that the A/C air intermittently changes from cold air to cool to lukewarm air. During the lukewarm air stage, the air tends to be particularly humid. So, my question is, why do you believe that when it gives cool to lukewarm air and why the air is humid? Is this a result of moisture being trapped in the A/C line? Or is this resulting from a different issue in the A/C unit?
May 28, 2022 at 3:55 PM
