A/C compressor and engine fans are not spinning?
2018 GMC SIERRA
138,000 MILES • 6.2L • V8 • 4WD • AUTOMATIC
COLEWILEY21
Fans are not spinning, compressor clutch not engaging, fuses to my knowledge seem fine. Heat works A/C blows hot air.
Apr 8, 2023 at 4:28 PM
If the fuses are good, make sure the connection to the compressor clutch is in good condition and tight.
Keep in mind, there are a few things that can cause this to happen. If the low-pressure switch is faulty, it may not allow the compressor to engage.
Next, if the Freon is low, that will cause the pressure to drop and actuate the low-pressure switch to avoid it from engaging.
Do me a favor. Take a look through this link and let me know if anything is helpful. It goes through things to check and how to repair them when the system doesn't engage.
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
Let me know if that helps.
Take care and Happy Easter,
Apr 8, 2023 at 10:08 PM
