My A/C started blowing hot air recently. After a brief check I found a leak on the high pressure hose which was replaced. A/C now blows okay, but lately I noticed that the compressor is not cycling on and off. The compressor was cycling on and off when my mechanic friend vacuum and recharged the system. Now it runs constantly without clutch disengaging. Just to add the fan and A/C on/off switch works okay. Both switches disengage clutch when set to off. Is this something I need to worry about? I live in Florida. Also, if I need to change the pressure switch can I do so without recharging the system again? Thanks for your help.
Jul 16, 2019 at 6:47 PM
