A/C Compressor is always on?
2002 GMC SUBURBAN
160,000 MILES
EYAD ALHERZ
The A/C compressor will start running whenever i turn the A/C on. However, it is not cycling on and off.
I tried removing the low-pressure switch, but the A/C compressor was still engaged.
The strange thing was when the freon leaked this week, the compressor was not engaging at all.
May 11, 2023 at 6:20 PM
If the Freon is low, it can cause it to run at all times. How quickly is it losing Freon? Take a look through this link if it has stopped working.
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
If the freon was lost, that is what the low pressure is for. It will prevent the compressor from engaging. Also, try switching the compressor relay with a different one in the box having the same part number and see if that makes a difference.
May 12, 2023 at 8:29 PM
EYAD ALHERZ
Thank you for replying to me. However, my concern is how possible if the low pressure switch was removed, and the compressor still running?
May 13, 2023 at 1:11 AM
That is a good question. Something had to be sending a signal. Is there any evidence of wiring damage?
May 13, 2023 at 10:08 PM
