Welcome back:
Static pressure is the pressure in the system when it is off and hasn't been run for awhile. Both sides will be the same or extremely close. If you have gauges, let me know what it is. Also, if pressure is where it should be, then I am going to ask you to check the wire that runs to the compressor clutch to see if it gets power when you turn on the AC. The clutch could be bad, too. Another way to check the compressor clutch is to simply apply 12v to it. When you do that, it should click.
I have flow charts related to clutch not engaging and how to check the circuit. I am going to provide them. You're listed as a mechanic, so you should be fine with these.
Note: There are directions for both Manual AC and Automatic AC.
_____________________
I'm starting with the manual. The attached pictures basically the directions.
2006 Nissan-Datsun Truck Titan 2WD V8-5.6L (VK56DE)
Manual Air Conditioner
Vehicle Heating and Air Conditioning Compressor Clutch Testing and Inspection Component Tests and General Diagnostics Manual Air Conditioner
MANUAL AIR CONDITIONER
Magnet Clutch Circuit
SYMPTOM: Magnet clutch does not engage.
Inspection Flow
pic 1
INSPECTION FLOW
SYSTEM DESCRIPTION
The front air control controls compressor operation based on ambient and intake temperature and a signal from ECM.
Low Temperature Protection Control
The front air control will turn the compressor ON or OFF as determined by a signal detected by the intake sensor.
When intake air temperature is higher than the preset value, the compressor turns ON. The compressor turns OFF when intake air temperature is lower than the preset value.
Diagnostic Procedure For Magnet Clutch
Pic 2
Diagnostic Procedure For Magnet Clutch (Steps 1 - 2)
pic 3
Diagnostic Procedure For Magnet Clutch (Steps 3 - 6)
pic 4
Diagnostic Procedure For Magnet Clutch (Steps 7 - 9)
pic 5
Diagnostic Procedure For Magnet Clutch (Steps 10 - 12)
pic 6
DIAGNOSTIC PROCEDURE FOR MAGNET CLUTCH
SYMPTOM: Magnet clutch does not engage when A/C switch is ON.
________________________________________
Here are the directions for automatic AC.
Automatic Air Conditioner
Vehicle Heating and Air Conditioning Compressor Clutch Testing and Inspection Component Tests and General Diagnostics Automatic Air Conditioner
AUTOMATIC AIR CONDITIONER
Inspection Flow
pic 7
INSPECTION FLOW
SYSTEM DESCRIPTION
pic 8
The front air control will turn the compressor ON or OFF as determined by a signal detected by the intake sensor and the ambient sensor.
When intake air temperature is higher than the preset value, the compressor turns ON. The compressor turns OFF when intake air temperature is lower than the preset value. That preset value is dependent on the ambient temperature, refer to the table.
pic 9
pic 10
pic 11
pic 12
pic 13
Diagnostic Procedure For Magnet Clutch (Steps 13 - 17)
pic 14
Diagnostic Procedure For Magnet Clutch (Steps 18 -20)
pic 15
Diagnostic Procedure For Magnet Clutch (Steps 21 - 23)
pic 16
Diagnostic Procedure For Magnet Clutch (Steps 24 - 25)
pic 17
Aug 19, 2019 at 7:27 PM
