Certainly, you can drive with it off. When someone said the car may stop may be thinking of the compressor locking up, but that doesn't happen too often. If it does, you will hear the A/C belt starting to screech. Eventually
As far as the problem, it likely just needs freon added. I don't know if you are comfortable doing it, but here is a link that explains how it's done:
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
If you want to try, let me know and I'll help. Also, you can purchase the freon at nearly any parts store.
Let me know what I can do to help or if you have other questions. Also, if it is excessively hot where you are, it isn't out of the ordinary to hear a whine. The pressure in the system increases with heat which can result in noise.
Also, if the compressor locks, as mentioned, you will hear screeching from the belt, being unable to turn the pulley. The belt can eventually break and the vehicle at that point should be turned off, but it will give you a minute to safely exit the road. So, unless you hear loud screeching, relax. You'll be fine.
Sep 6, 2022 at 8:39 PM
