ac clutch will not re-engage
1998 LINCOLN CONTINENTAL
120,000 MILES • 4.6L • V8 • FWD • AUTOMATIC
HWHOUND
static pressure with car off 90 psi low side 110psi high side.
start the car with A/C on compressor engages low side goes to 25psi
high side goes up to 175 psi.
clutch cycles and pressures go to 90 psi low side 110 psi high side and clutch never re engages. start car with A/C off, turn on A/C the pressure stays at
90 psi low side 110 psi high side and clutch never engages.
Apr 14, 2017 at 2:54 PM
HMAC300
  • 48,601 POSTS
check fuses and relay under hood first then if still doing It a mechanic will have to scan for codes to see what is wrong not allowing it to turn on
Apr 15, 2017 at 7:07 AM
