1. Looks like our manual does not have the belt routing with no AC. I would not recommend this anyway. I would just do an internet search for an AC compressor bypass pulley that fits your engine. Basically, this is just a pulley that bolts in place of your compressor and it allows you to use the stock belt and doesn't require any alterations.
2. You can find a clutch rebuild kit that has the needed parts just to replace the clutch. Most parts stores do that just because not many people do just the clutches any more so they don't sell them. Supply and demand.
3. That appears to be just the hub. The clutch would go on the back of that and probably is part of the pulley itself.
Oct 3, 2019 at 8:10 PM
