A/C clutch not engaging just blows hot air
2001 SATURN SL1
226,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
RODNEY7867
  • 70 POSTS
When i turn on A/C it just blows out hot air i watch rpm's and they don't budge. I thought it does if at least the HVAC controls inside is working. I cant add Freon without compressor on and i don't know what to try.
Jul 5, 2019 at 6:35 PM
Welcome to 2CarPros.
Is the AC compressor engaging? You will hear it click. Also, why can't you add Freon?
Take a look through this link:
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
Let me know exactly what is going on and if either of the aforementioned links are helpful.
Jul 5, 2019 at 7:07 PM
RODNEY7867
  • 70 POSTS
The A/C compressor not engaging not coming on no power to it. took multi-meter to it today it has no power going to it.
Jul 6, 2019 at 7:09 AM
RODNEY7867
  • 70 POSTS
I read the BCM controls the power locks and A/C on my car. The power locks were draining my battery so i pulled the fuse for the power locks but what i curios about is if the BCM controls both and the locks drained the battery could it be the BCM fuse being bad?
Jul 6, 2019 at 1:06 PM
RODNEY7867
  • 70 POSTS
Well, i found the body fuse replaced them. now i have power at compressor but clutch still doesn't kick on. i put one of those reusable gauges you get with the refrigerant and it is reading 100 in the red.
Jul 6, 2019 at 4:11 PM
Welcome back:
Okay, now that we have power, I need to know a few things. First, the 100 psi reading, is that static pressure (everything off)? Also, do you have an AC manifold gauge set that we could also check the high side pressure?
Let me know. Also, let me know the outside temperature when checked. If both sides are 100 psi static, that isn't and issue, but I need to know if they are equal.
Jul 6, 2019 at 8:04 PM
RODNEY7867
  • 70 POSTS
I don't have a manifold system. i only had the gauge that comes om the trigger recharge can. The reading was with car running A/C on.
Jul 7, 2019 at 5:27 AM
RODNEY7867
  • 70 POSTS
I replaced clutch still have to put belt back on.
Jul 7, 2019 at 6:03 PM
Welcome back:
Let me know the outcome.
Take care:
Jul 7, 2019 at 7:31 PM
RODNEY7867
  • 70 POSTS
Well, i found the issue, it is the wires that go to switch. I figured it out by process of elimination. Last time i had no power i checked all fuses and i messed with the wire connector to the control panel now i have reconnected everything else and no power again to anything and again i check and for good measure i got all new and replaced them. With double check wire connector and get back to you.
Jul 9, 2019 at 2:59 PM
Welcome back:
I have attached three pics that I hope help. The first is the switch assembly and the next two are what each wire is used for which goes to the power switch, AC, mode control and so on. Picture 2 deals specifically with the AC.
Here are a few links you may find helpful:
Let me know if it helps.
Jul 9, 2019 at 7:28 PM
RODNEY7867
  • 70 POSTS
Will A/C system have power if control panel is messed up?
Jul 10, 2019 at 2:20 AM
In most cases, no. However, the compressor isn't working correct?
Jul 10, 2019 at 7:53 PM
RODNEY7867
  • 70 POSTS
I replaced the control panel and everything works. cold A/C, hot heat. thanks for the help.
Jul 11, 2019 at 5:14 AM
Welcome back:
Great!!! I'm glad you got it working. Let us know if you need help in the future.
Jul 11, 2019 at 7:18 PM
RODNEY7867
  • 70 POSTS
I have new issue my Saturn sl1 2001 taat transmission slams into revers and to all gears except what i believe is fourth if there is a fourth.
Sep 16, 2019 at 7:00 PM
Welcome back:
I hate to ask this, but I need you to start a new thread related to the transmission issue. We are trying to keep the threads specific to one topic so it helps others.
I hope you understand.
Sep 16, 2019 at 7:08 PM
