My vehicle listed above A/C Clutch is not engaging without bypassing it using a paperclip in the Relay. This allows it to blow cold. The A/C Clutch Relay Fuse under the hood was replaced and didn't fix this issue. The vehicle had A/C when I bought it and it was fixed once. Had a leak and was patched with no additional work added. After it was patched, it blew cold, but it took a while to get there. Approximately 2-5 minutes. My guess is there isn't enough Refrigerant 134a to allow the ac to kick on (A/C High/Low switch but I don't want to refill it for it not to work still.
Jun 21, 2023 at 5:50 PM
