A/C clutch not working
2004 CHRYSLER PT CRUISER
160,000 MILES
TONY02
  • 86 POSTS
So recently I did a timing belt job on my car listed above and I discharged the A/C system and when I was ready to put refrigerant back in it the A/C clutch wasn’t kicking on. so I ended up jumping the relay and it turned on and now the system is fully charged. But my A/C clutch still isn’t turning on by itself. I swapped the relay and still nothing. I checked the fuses and it’s all good. I also replaced the low pressure switch on it and I’m still getting nothing. any advice on what I should do next? It seems that the only way the A/C clutch turns on is when I jump the relay.
May 8, 2020 at 10:18 AM
Good afternoon,
I attached a wiring diagram for the A/C compressor.
Can you remove the relay and with the key on? you should have 2 powers in the connector.
Can you verify this?
Can you check for power as well at the high and low pressure switches?
May 8, 2020 at 10:36 AM
TONY02
  • 86 POSTS
Okay, so with the key on at the relay I do have two power connectors, but as for the high and low pressure switches I have nothing, but when I turn the car on and A/C on I do get a ground at both switches but no power.
May 8, 2020 at 6:00 PM
The power for the switches comes from the control head. If there is no power, go to the control head and see if the wire, brown, has power when the A/C is commanded on.
If it does, you have a wiring issue, if it does not, then the control head is bad.
Without the signals from the 2 pressure switches, the PCM will not ground the control side of the A/C relay for the compressor to come on.
May 9, 2020 at 1:54 AM
TONY02
  • 86 POSTS
The control head would be inside the car right the instrument panel that controls all the A/C stuff by the radio? If so then yea the brown wire isn’t getting no power so that would mean the control head is bad then?
May 9, 2020 at 8:54 AM
That is correct. That is where the power comes from.
I attached a picture of the control for you.
May 10, 2020 at 2:26 AM
TONY02
  • 86 POSTS
Okay, thanks so much for the help. I will go head and replace it and I’ll update it when I do.
May 10, 2020 at 5:34 AM
You are welcome.
Always glad to help.
May 10, 2020 at 5:35 AM
TONY02
  • 86 POSTS
Hey, so I know it’s been a while but I finally had a chance to replace the control head with a brand new one but still the A/C clutch doesn’t engage. I also back probed it to check for power at the brown wire and I still have nothing.
May 19, 2020 at 6:36 PM
Okay, when you checked the brown wire, was the engine running and the A/C commanded on?
May 20, 2020 at 6:17 AM
TONY02
  • 86 POSTS
Yes, I put the A/C on high.
May 20, 2020 at 10:56 AM
If you disconnect the connector with the key on, does the brown wire have any power?
May 20, 2020 at 11:03 AM
TONY02
  • 86 POSTS
No the brown wire doesn’t have any power.
May 20, 2020 at 11:26 AM
I attached a wiring diagram for you.
check the voltage on both sides of the fuse with the key in the on position.
May 20, 2020 at 11:33 AM
TONY02
  • 86 POSTS
Okay, so I checked the fuses you said to check and they are good. I used a test light connected to battery ground and it lit up on both sides for all of them.
May 20, 2020 at 5:36 PM
Okay, it is pointing right back to the control head again.
Where did you get the control head?
May 21, 2020 at 4:21 AM
TONY02
  • 86 POSTS
I got it at AutoZone.
May 21, 2020 at 6:02 AM
I would return it for another one.
All tests show it is this unit that is bad.
May 21, 2020 at 6:07 AM
TONY02
  • 86 POSTS
Okay, I returned it and got another one at O'Riley’s. I will update when it comes in to see if it’s good or not.
May 21, 2020 at 10:29 PM
Sounds like a plan.
We will be here.
May 22, 2020 at 4:08 AM
TONY02
  • 86 POSTS
Okay, so it came and and I installed it and still same thing I’m not getting power at the brown wire and the clutch isn’t engaging. at this point I’m thinking of just jumping the relay with a jumper wire and leaving it like that, but my only concern is will this mess up the compressor by having the clutch engaged at all times?
May 28, 2020 at 4:08 PM
It will work as long as you have cold air. The moment it does not have cold air, remove the jumper wire and have the freon system tested for a leak and charged.
https://www.2carpros.com/articles/air-conditioner-leak-detection
It will not hurt the compressor.
May 28, 2020 at 4:16 PM
TONY02
  • 86 POSTS
Okay, thanks. I will just do that then.
May 28, 2020 at 4:26 PM
TONY02
  • 86 POSTS
I have another question but it’s about a different car it’s a 2004 Ford Explorer do you think you can tell where the reverse gear signal wire is located at? I installed a reverse back up camera and I need to hook that wire up.
May 28, 2020 at 6:55 PM
Site policy I can only address one vehicle at a time per question.
Can you please start a new question? The reason being; in order for the site to properly index the questions they need to about one issue/vehicle otherwise people will not be able to find the answer to this question under a different subject. The premise of our site is to assist those that need direct help and also provide a resource for others that have the same issue.
For your convenience here is the link: https://www.2carpros.com/questions/new
Make sure you are logged into the site before clicking on the link
May 29, 2020 at 4:08 AM
TONY02
  • 86 POSTS
Okay, will do.
May 29, 2020 at 5:35 AM
