Ac clutch
1998 DODGE VAN
154,000 MILES • 5.9L • V8 • 2WD • AUTOMATIC
FRAN-TRUI
Compressive runs clutch will not run unless I jumper out
Dec 28, 2015 at 12:37 PM
WRENCHTECH
  • 20,761 POSTS
There are dozens of reasons the clutch will not engage. Unless you can understand a wiring diagram and test the circuit, about all you can do yourself is test all the fuses in the truck with a test light.
Dec 28, 2015 at 1:42 PM
WRENCHTECH
  • 20,761 POSTS
You also need to put gauges on the system to make sure there is enough static pressure to allow the clutch to engage.
Dec 28, 2015 at 1:43 PM
