A/C charging with small cans?
1999 JEEP WRANGLER TJ
210,035 MILES • 2.5L • 4 CYL • 4WD • MANUAL
ATYRONE30
I recently watched your video on vacuuming and charging the A/C. I recently put a new A/C system in my vehicle since it never had one. I'm going to be using cans (24oz total) to charge it. Am I able to just switch out a can when it runs out or do I have to turn everything off, close the low side then change the can out?
May 28, 2023 at 9:16 AM
CARADIODOC
  • 34,306 POSTS
Your charging hose will have a valve to close, then switch it to the next can and reopen the valve. No need to stop the engine.
Here's some pointers that might help. First, keep the can upright at all times when it's flowing refrigerant. You only want the vapor going into the system. If you tip it over, you'll get liquid going into the low side where it could get into the compressor. At best that will just lock it up for a few hours. At worst it can damage the pistons and valves.
If it takes a painful amount of time to empty a can, set it in a pot of hot water. After waiting over 20 minutes, that has worked for me to empty the can in less than half a minute.
The amount of refrigerant is critical for proper operation. Too much is just as bad as too little. Chrysler is the only manufacturer that provides a means to know when the system is fully-charged. If this is a dealer's OEM kit, there will be a small sight glass on top of the receiver / drier. It's only about 1/4" in diameter. Keep adding refrigerant just until the vapor bubbles stop flowing through that window. At that point the evaporator in the dash will be very close to half-filled with liquid and half with vapor. That's the point at which it changes state from liquid to vapor, and that's the point at which it gets very cold. With too little refrigerant, that point will be in the high-side hose under the hood. You're likely to see frost developing on the hose in the area where it's changing state. You don't want the cooling to occur there. Likewise, with too much refrigerant, it will change state in the low-pressure hose under the hood; another place the cooling won't do any good. If liquid gets into that hose, it can slosh into the compressor and damage it.
For our Ford friends, it's important to point out they also used a sight glass starting in the '80s, but they must never be used. When the system is fully-charged and even badly over-charged, there will still be vapor bubbles in that window. It's a great idea that doesn't work on those vehicles.
It's also important to watch what you get for air temperature at the ducts. 60 degrees F. is very respectable. That's sweater-wearing temperature. Some people will brag that theirs gets down to 40 degrees, but that indicates something is wrong. To take 70 degree outside air and get it to 40 degrees at the ducts means the evaporator needs to be much too cold. The biggest comfort comes from removing the humidity from the air. That moisture condenses on the evaporator and drips onto the ground. All AC systems are regulated to limit the temperature drop to no lower than 40 degrees. That's already getting dangerously close to 32 degrees, the point at which that condensation will freeze into a block of solid ice. That will block air flow and stop the cooling. If your system uses a gas-charged sensing bulb on the evaporator, be sure that is located in the spot specified so it regulates properly. Many systems today use pressure instead of temperature to control the flow of refrigerant. The older R-12 had a neat characteristic where, when the system is at rest, its temperature will very closely equal its pressure, as long as there's some liquid and some vapor in the system. The newer R-134 is similar, so a pressure switch can be used to cycle the compressor on and off.
For my last comment of value, don't get excited if you see a little bubbling at the charging port when you disconnect the hose. That is common. The valve in that port is only intended to hold the refrigerant in while you screw on the plastic cap. The sealing is done with the rubber O-ring in that cap.
Here's links to some articles that might cover something I missed:
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Let me know how this turns out.
May 28, 2023 at 5:32 PM
ATYRONE30
Thanks, I do have one more question. When doing the vacuum does it also take out any oil in the system? The kit I ordered came with oil in it already. If it does remove it, how would I put it back in?
May 28, 2023 at 10:51 PM
CARADIODOC
  • 34,306 POSTS
Nope. There is a specified amount of oil for each part, including hoses, evaporator, and condenser, but most is in the compressor. That oil circulates through the system with the refrigerant. When you pump the system into a vacuum, any moisture or water will boil at 77 degrees and turn into a vapor that can be drawn out. That is the purpose of putting the system into a vacuum before charging it.
The receiver / drier can hold about ten droplets of water, but we want that water out of there. It promotes corrosion of metal parts and can freeze at the expansion valve and block the flow of refrigerant, usually intermittently. The oil does not vaporize and will not be drawn out.
When you have a small leak, the refrigerant will sneak out over time, but as long as there's just a little pressure in the system, higher than atmospheric pressure, no air or humidity will get in. That means there's no need to put the system into a vacuum when just adding some refrigerant. Professional charging hoses have check valves built in to keep some refrigerant in them at all times when they're disconnected. When you use the little cans with do-it-yourselfer hoses, a common practice is to loosen the charging hose at the vehicle's low side charging port, then open the valve on the can for a fraction of a second, then retighten the hose fitting. That puts a little refrigerant into the charging hose and purges any air along with the humidity in it. Be sure to be wearing gloves when working with that fitting.
You'll notice every part in your kit had plugs, caps, or seals on them to prevent air from getting in. That makes it easier to get any moisture removed when it's pumped into a vacuum. If your vacuum pump has a gauge on it, watch if it holds vacuum after pumping the system for about a half hour. If you see the gauge jump up a little the instant you turn the pump off, there's still water in the system that's boiling. It expands as it turns to a vapor so the vacuum reading goes down. Pump it for another half hour to give that water more time to boil out. You're more likely to run into that when the system has been open for a long time. Some people don't plug the hoses or other parts, for example, when waiting days or weeks for an ordered part to arrive.
If you see the gauge rise very slowly over five or ten minutes, there's most likely a small leak. The best way to find that is to put in just a little refrigerant, then check at each connection with an electronic leak detector. You should be able to borrow one of those from an auto parts store that rents or borrows tools. When "sniffing" around a part or connection, place the tester's probe under it because refrigerant is heavier than air and will flow down to the probe, not up.
May 29, 2023 at 4:53 PM
