Hi guys
I have a problem with a hyundai verna model from 2004. I would appreciate any help with this problem
the problem is that it overheats only when
------ its a hot day and I am stuck in traffic and and the AC is on. Sometimes it overheats during motion but only on hot days and when the AC is on.
The way it overheats is that it goes outside the proper temp mark and stay somewhere in the middle between the danger red mark and proper temp mark.
It doesn't overheat in any other situation.
here is what I did so far
- replaced the radiator
- replaced the radiator cap
- Flushed the cooling system
- Flush the external of the radiator and the ac condenser
what else should I do?
notes;
1)the condenser had a very small hole in it after a minor crash ( it got pushed up against the radiator and one one the radiator screws or sth poked a hole into the condenser) and I got it welded shut.
2)the radiator fan is not the stock fan of the car. Is there a way to confirm that its blowing at the right speed. I made sure that both the ac fan and radiator fan are running when the car overheats.
notes;
Jul 31, 2013 at 8:25 PM
