AC burning smell? Rough shifting from engine
2002 FORD WINDSTAR
72,000 MILES • 6 CYL • AUTOMATIC
SEAN 1960
Hi guys,
Seems that after a couple of hours of driving with the AC on I start to get a burning smell. I'm not sure if it's electrical wiring or belt rubber. I did see a little smoke come from the side of the car where the AC is situated and the belt is just under where I've seen condensation on the AC tubes.The AC is working fine. (At least in the front.) The pipes are sopping wet while the AC is on.
Also , when I hit 40 and 65MPH(approximately) The shifting gets a little rough. I had the Transmission fluid and filters changed but the problem still persists.
Any help would be appreciated...
Sean
Aug 27, 2015 at 6:43 AM
HMAC300
  • 48,601 POSTS
scan for codes and have blet checked may be the tensioner is worn out or belt is wearing badly.
Aug 27, 2015 at 6:48 AM
