A/C blows super cold at night but on hot summer day barely cools car
2005 FORD FOCUS
289,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
CHRISCHUNG221
  • 17 POSTS
My A/C will literally blow so cold even on number 1 that in the evening i have to turn it off. It might be 80 degrees outside. However if temperatures hit 95 and above during the day, can barely feel the A/C. What gives? Any ideas? Was thinking maybe to tint the windows?
Feb 16, 2020 at 4:33 PM
JOETECHPRO
  • 705 POSTS
Hey CHRISCHUNG221,
When you turn the A/C on at idle does the radiator cooling fan cut in?
It should cut in shortly after you turn the A/C on to provide enough air flow to cool the condenser.
If this is okay i would next suspect either a low refrigerant charge or a slipping A/C belt.
Have you had the A/C serviced since you have owned the vehicle?
Regards, Joe
Feb 16, 2020 at 10:51 PM
CHRISCHUNG221
  • 17 POSTS
Thanks for the quick reply! No, haven't had the AC serviced. Radiator fan does cut on. Charged the refrigerant. Would it be able to cool properly at anytime if the belt was slipping? It gets super cold if the temperature is in the 80's. I'd hate to see what Ford charges to service the A/C. Probably more than the blue book value of the car.
Feb 17, 2020 at 4:58 PM
Lets double check the charge for the AC using this video and this AC not working guide:
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
and
https://youtu.be/uZrQCGwXfek
Feb 17, 2020 at 7:21 PM
