AC blows out air but it is not cold
1999 ISUZU TROOPER
152,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
DALLAS HENRY
When I turn the AC on it blows out air but it is not cold. My uncle said maybe the compressor, but how will I know? Also, when I put the SUV in park the rpm's go up to 2,100.
Sep 26, 2018 at 8:53 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Have you noticed if the compressor is cycling? When was the last time the A/C system was serviced (refrigerant added)? The system has a cut-off switch that shuts the compressor off if a low level of refrigerant is detected. That is to prevent damage until proper level is corrected. I have attached a few tutorials for you to view.Hope this helps and thanks for using 2CarPros.
Danny-
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
https://www.2carpros.com/articles/air-conditioner-leak-detection
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Sep 26, 2018 at 12:34 PM
DUWHOP31
  • 151 POSTS
Okay, so when I turn on the AC it does not make a squealing noise. Do I put the AC charge on the low port with the car on and AC running or with the car off?
Sep 27, 2018 at 8:37 AM
DANNY L
  • 5,648 POSTS
Hello again.
You add to the low side (only fits on that port) with car running and controls on Max A/C. It may take awhile it enters slowly. Hope this helps and thanks again for using 2Carpros.
Danny-
Sep 27, 2018 at 5:05 PM
DUWHOP31
  • 151 POSTS
The gauge reads zero when it is off or on with AC on max.
Sep 28, 2018 at 8:16 AM
DANNY L
  • 5,648 POSTS
Hello again.
It usually takes a while if using a recharge can for enough to enter to get the compressor to cycle. Has the A/C been working recently and then quit? It is also possible you have a major leak in the system. I have attached a tutorial show leak detection. Hope this helps.
Danny-
Sep 28, 2018 at 4:42 PM
