Good morning,
Can you check and see if there is any pressure in the A/C system? If you are low in Freon, it will not come on and blow cold air.
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
Can you see if the clutch is engaged for the compressor with the A/C commanded on?
I attached a wiring diagram for you to view. Make sure you check the 3 fuses I highlighted for power on both sides.
Feb 21, 2020 at 4:18 AM
