A/C blows hot
2004 CHEVROLET SILVERADO
130,000 MILES • V8 • 4WD • AUTOMATIC
MARK Z
Compressor seems to be engaging. Checked charge and was way overcharged so I decompressed to normal operating range. Checked fuses and relays and still blows hot On both sides. Any ideas? Could it be the actuators?
Jun 7, 2018 at 5:25 PM
Good evening.
What were the exact high and low side pressures while running?
Lets start there.
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Jun 7, 2018 at 8:49 PM
MARK Z
I was only able to check the high side using a gauge from a r134a can charger. It was pegged out at 150. Obviously I did not add any to the truck just released the pressure to normal operating range.
Jun 8, 2018 at 6:33 AM
That is the low pressure. You need to get a set of gauges to monitor both sides.
You can rent a set at a parts store or buy a set at Harbor Freight for about $30.00.
Then we can get accurate reading and help you out.
150 on the low side is excessive. Was any Freon added prior to this?
Was the A/C working correctly before?
Were there any parts replaced?
Jun 8, 2018 at 11:20 AM
