Low side pressure is on high side and A/C clutch not engaging. Ran Nissan diagnostic test and determined A/C coil was bad. Replaced clutch assembly. During repair found that old coil had burnt out. Now diagnostic test shows coil is actuating clutch however the clutch still does not engage when A/C is on. Suspect the low side switch is preventing clutch from engaging.
Any suggestions on what to try next?
Jun 8, 2020 at 5:40 PM
