AC blower will not work, compressor runs when ac is turned on.
2003 SATURN L300
156,000 MILES • 3.0L • 6 CYL • AUTOMATIC
LEVICNO
AC in my daughters car worked fine until she pulled up in front of the house 2 nights ago. She gets in the car yesterday morning and the ac could not blow air.
The compressor comes on as it should, the readings on the ac control read perfectly, yet the ac fails to blow.
What possibly could be the problem that prevents the blower from blowing?
I read a response by your saturntech9 to a problem I just fixed on my vehicle recently. The answer was exactly what I undertook to fix my problem.
Aug 20, 2015 at 8:12 AM
RIVERMIKERAT
  • 6,110 POSTS
Check the ground wire to the blower. Those are notorious for vibrating off. If that's not it, check the fuses and relays for the system.
Aug 20, 2015 at 8:19 AM
LEVICNO
I have checked the fuses and relays and they all seem to be good, the grounding to the blower still connected. In the absence of these check, what else should I check?
Aug 20, 2015 at 12:28 PM
RIVERMIKERAT
  • 6,110 POSTS
If you're sure the fuses and relays are all good, now you get to play detective and find out where the current stops and why. Is it an automatic or manual AC system?
Aug 20, 2015 at 1:05 PM
LEVICNO
It is automatic with climate control. I forgot to mention earlier, the fan work properly. In this scenario, it's only the blower that does not operate.
Aug 20, 2015 at 4:14 PM
RIVERMIKERAT
  • 6,110 POSTS
Ok, so no air comes out of the vents whatsoever? I have attached the schematics for the A/C system in your car. You will need to use a meter or test light to see where current is being stopped.
By "fan" I presume you mean the one at the radiator?
Aug 20, 2015 at 5:01 PM
