A/C blower not working
2001 SUZUKI BALENO
100,000 MILES • 1.3L • 2WD • MANUAL
AAMIRNASEER
Car air blower not working.
Mar 22, 2020 at 12:18 PM
Have you checked fuses? Does it work on high speed only? This specific model isn't offered in the US, so I don't have specifics. However, I would recommend checking fuses and for power to the blower motor.
Here are a few links you may find helpful:
https://www.2carpros.com/articles/how-a-car-fuse-works
Let me know what you find. Also, feel free to ask questions. If I can help, I will.
Mar 22, 2020 at 1:04 PM
SCGRANTURISMO
  • 4,897 POSTS
Since I have never heard of this vehicle, nor is it in our reference guides, I assume that you are not living in the United States, but abroad. Therefore I cannot send you any wiring diagrams to help you out with this, but I would find the blower motor, undoubtedly located in the dashboard or under it and then locate it's electrical connector. With the vehicle either running or in the ignition key in the "run" position and not started, take a voltage reading on the positive wire and see if you are receiving battery voltage there. If not trace the wire back to the battery and look for problems. Next, follow the ground wire and make sure that the ground is clean, tight, corrosion free, and making good metal to metal contact. Please check these out and get back to us with what you find out. We can go from there if necessary.
Thanks,
Alex
2CarPros
Mar 22, 2020 at 1:10 PM
