Where is the A/C blend door actuator located?
2007 CHEVROLET SILVERADO
140,000 MILES • 5.6L • V8 • 2WD • AUTOMATIC
SKIUAW12
  • 5 POSTS
My truck listed above LT 4 door, won't blow cold air out of the driver's side A/C vents (2). Recalibrated and that lasted 2 weeks. Would appreciate any advice on removing and replacing the A/C door vent actuator. Thanks in advance.
Aug 31, 2021 at 12:23 AM
SQM
  • 6,383 POSTS
Typically when the plastic gears inside the actuator breaks it will get stuck in one position.
The blend door actuator can be accessed through under the dash. You will have to remove few trim pieces.
We have a very good video on how to do that on the similar year truck, you might find this helpful:
https://youtu.be/tY6M92fA2ug
Thank you.
Aug 31, 2021 at 8:10 AM
SKIUAW12
  • 5 POSTS
Thanks. I have a part coming later this week. This will help.
Aug 31, 2021 at 12:34 PM
SQM
  • 6,383 POSTS
Great. Let me know if you come across any issues.
Aug 31, 2021 at 12:38 PM
