If the belt is broken, it has to be replaced. You indicated you don't have the money to get one. I'm not sure how to help. As far as the AC, is the pulley locked up?
I don't know if it will help, but here are the directions for replacing the belt. The attached pics correlate with the directions.
________________________________________________________
2014 Dodge Avenger V6-3.6L
Serpentine Accessory Drive Belt - Installation
Vehicle Engine, Cooling and Exhaust Engine Drive Belts, Mounts, Brackets and Accessories Drive Belt Service and Repair Removal and Replacement Serpentine Accessory Drive Belt - Installation
SERPENTINE ACCESSORY DRIVE BELT - INSTALLATION
3.6L
pic 1
1. Check the condition of all pulleys.
CAUTION:
When installing the serpentine accessory drive belt, the belt MUST be routed correctly. If not, the engine may overheat due to the water pump rotating in the wrong direction.
2. Install new belt (7). Route the belt around all pulleys except the idler pulley (2). Rotate the tensioner arm (8) until it contacts its stop position. Route the belt (7) around the idler (2) and slowly let the tensioner (8) rotate into the belt. Make sure the belt (7) is seated onto all pulleys.
pic 2
3. With the drive belt installed, inspect the belt wear indicator. The gap between the tang and the housing stop ( measurement A ) must not exceed 24 mm (.94 inches).
4. Install the inner splash shield.
5. Install the wheel.
6. Lower vehicle.
7. Connect the negative battery.
Take care and God Bless,
Feb 12, 2021 at 7:16 PM
