The A/C will not operate, but you may also encounter an issue if you are in a cold area and need to run the defroster. Like most newer vehicles the defrost position cycles the A/C compressor to help dry the air going onto the glass. Without it you could get a fogged windshield.
I would also be concerned that if the A/C belt failed the other belt may fail as well.
Dec 9, 2016 at 9:10 PM
