blower motor not working
2000 TOYOTA TUNDRA
337,000 MILES • 4.7L • V8 • 2WD • AUTOMATIC
DAVID SAULS
My air conditioner was working, but the blower motor was making a very loud noise and vibrating the dash. After a few days, I went to turn it on to show a friend the noise for advice. The motor would not come on at all. I replaced the relay and the blower motor. I also cleaned out all the leaves and debris behind the resistor. The same results though. Nothing happens when I turn the switch on. What could it be?
Jul 30, 2016 at 11:45 AM
SATURNTECH9
  • 30,869 POSTS
Have you checked all the fuses? that should have its own fuse.
Jul 30, 2016 at 12:22 PM
CJ MEDEVAC
  • 11,004 POSTS
I have been on "Prodemand"
I have found a diagram (it had two choices-Limited and SR-5) I chose the Limited, the diagrams maybe the same for the air conditioner circuits, if not, I will get the other for you.
I can only screenshot the diagrams in Prodemand.
It took three shots, they overlap, so there is no missing information.
Picture one is top/ two is middle/ three is bottom.
Locations of the components are listed, the blower itself is on the first diagram sort of bottom right.
Keep us posted on progress!
The Medic
Jul 30, 2016 at 12:37 PM
