A/C and heat issues
2007 FORD FIVE HUNDRED
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
IMCGM
So I see the question in both section, but I have a car that the A/C and the heat do not cool/heat properly at idle but both do at RPM. Any thought on a common link?
Thanks, mike
Oct 18, 2018 at 8:28 AM
When you say dont work properly do you mean temperature or the air stops flowing from the vents?
Please let me know, Ken
Oct 19, 2018 at 12:35 PM
IMCGM
There is no restriction of air, the flow is always consistent. It is just the temperature that is inconsistent, and being that I am having the same problem with the heat and the A/C I though there might be a common denominator. So basically the word heat and A/C are interchangeable in this problem. At idle little to no AC/heat, at 2,000 to 3,000 rpm all is good. whether I am traveling down the road or at idle revving the the engine in the driveway.
Thanks.
Oct 19, 2018 at 1:04 PM
These would be two separate problems first I would check the level of the coolant for the heat problem. Next I would hang a set for gauges on it to see what the high and low side pressures are at idle because it sounds like the compressor is going out.
Here are two guides to help us get started:
and if bad
https://www.2carpros.com/articles/replace-air-conditioner-compressor
Oct 20, 2018 at 9:55 AM
IMCGM
I am fairly mechanically inclined and have checked most of the obvious problems. I am surprised to hear there is no common denominator between these two issues. My guess would have a head gasket or some odd vacuum problem. But I will keep looking. Oh, one thing I did not mention is 90% of the time you turn the climate control system on or off there is a kind of banging noise, like a wooden spoon against a plastic bowl kind of. I thought it was a vent attempting to open or close, but again I found no issues with airflow.
Thanks again,
Mike
Oct 21, 2018 at 10:20 AM
The only thing I can think of it the vibration of the engine must make the mode blend door actuator work. Let check the temperature blend door actuator. Here is a guide that will give you steps the change and check the door operation and the location of the actuator for your car below:
This will make the knock noise as well, put your hand on it to see if it is making the noise before you remove it. Check out the diagrams (below). Please let us know what you find.
Oct 22, 2018 at 10:35 AM
