After about 20 minutes of running the A/C, the air coming out the vents is slowly reduced until airflow is very limited, but it's still cold. If I turn the A/C off, the airflow comes back fairly quickly. The longer I leave it off, the longer it will work for. I've added refrigerant and the pressure is correct and not dropping. Could this be the evaporator coil freezing and melting? Any cheap fixes? Thanks!
Aug 6, 2022 at 7:47 PM
