Couple questions. First, I don't show dual zone temperature as an option on your vehicle but that is not always accurate and it would make more sense if you had dual zone temperature control. Meaning can you adjust the driver side to a different temperature then the passenger side or do you only have one temperature setting for the whole vehicle?
Next, when you say it does the same thing on heat, do you mean the air still blows cold on the driver side and hot on passenger side even if you turn it to the heat setting?
Jun 25, 2020 at 7:12 PM
