Do you have defrost selected? If so the A/C will run to dry out the incoming air to help prevent the windshield from fogging.
I you do not have defrost on, it is possible the clutch has an issue and is causing the compressor to keep turning. With the engine off, you can move the tension-er and loosen the belt. Now try turning the drive pulley by hand to see if the clutch is damaged.
Apr 11, 2017 at 2:47 PM
