AC clutch replacement
1995 BUICK LESABRE
185,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
BIKER ART
Need to replace the AC clutch in car. what is the procedure for doing this repair?
May 24, 2017 at 7:24 PM
WRENCHTECH
  • 20,761 POSTS
This is not recommended at all for a number of reasons. These clutches are pressed on and require special tools to remove and install and set up the spacing correctly. The clutches cost more than half of what a new compressor would cost and most of the time when the clutches fail they overheat and damage the front seal of the compressor anyway.There is also the issue of what caused it to fail in the first place Most of the time it happens because the compressor itself had started to freeze up for other reasons.
There is a whole lot more to consider in an AC failure than just the obvious damage. If the compressor had an internal failure, it will need a condenser also.
May 24, 2017 at 8:13 PM
