Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Nissan
Almera
Climate Control
Air Conditioner
Not Working
ac not working
1997 NISSAN ALMERA
155,000 MILES
BOZENA CAPA
MEMBER
FOLLOW
Hi, A/C compressor is not activated when l turn on A/C button. A/C button has three pins and only has power. relay and all fuses are okay.
May 28, 2017 at 12:12 PM
CERTIFIED EXPERT
First make sure the system has a good charge which you can do by following this link.
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Next here is a wiring diagram (BELOW) and a guide so you can do some testing. As you can see by the diagram there are many fuses that run the system.
and
Please run some tests and get back to us so we can continue helping you.
May 31, 2017 at 1:34 PM
BOZENA CAPA
MEMBER
I found the problem, the connector of temp sensor was disconected...a banal error- Thank you for your time.
May 31, 2017 at 2:13 PM
CERTIFIED EXPERT
Good to hear, please use 2CarPros anytime we are here to help.
Jun 1, 2017 at 11:21 AM
