A/C blowing hot air
2006 FORD FUSION
118,000 MILES • 4 CYL • 2WD • AUTOMATIC
NDAVIS712
The fan blows in the car but it’s hot air. I tried to add Freon but it acted like it wasn’t taking the Freon. How do I know if the compressor is working properly or if it just needs recharged?
May 7, 2019 at 1:50 PM
Good afternoon,
You can tell if you see the compressor clutch engaged when you turn on the AC.
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
Can you give me the high and low side pressures?
I attached a wire diagram for you to view. Check the fuses listed for power on both sides.
May 7, 2019 at 2:11 PM
