Good morning,
Do you have gauges that can give me the high and low side of the AC system while it is running?
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
When you command heat and cold in the front, do you hear the mode door move?
This could be a Freon issue or it could be a blend door issue.
INSPECTION
1. REMOVE LOWER FINISH PANEL
2. REMOVE NO.1 SAFETY PAD INSERT
3. REMOVE CLUSTER FINISH PANEL
4. REMOVE CENTER CLUSTER FINISH PANEL
5. REMOVE RADIO RECEIVER
6. REMOVE AIR MIX SERVOMOTOR
a. Disconnect the wire harness clamp.
b. Disconnect the connector.
c. Remove the 3 screws and air mix servomotor.
7. INSPECT AIR MIX SERVOMOTOR CIRCUIT
8. INSPECT AIR MIX DAMPER POSITION SENSOR CIRCUIT
9. INSTALL AIR MIX SERVOMOTOR
a. Install the air mix servomotor with 3 screws
b. Connect the connector.
c. Connect the wire harness clamp.
10. INSTALL RADIO RECEIVER
11. INSTALL CENTER CLUSTER FINISH PANEL
12. INSTALL CLUSTER FINISH PANEL
13. INSTALL NO.1 SAFETY PAD INSERT
14. INSTALL LOWER FINISH PANEL
May 21, 2019 at 2:53 AM
