A/C not blowing cold air?
2008 HONDA CIVIC
180,000 MILES • 4WD • MANUAL
STACEY MORREN
Which fuses should I check, because it isn't blowing cold air?
I've already put Freon in it and coolant in the reservoir tank.
Jul 23, 2021 at 3:44 PM
There are a couple of fuses to check and a compressor relay. Take a look at the pics below. I attached the entire wiring schematic for the A/C system. I highlighted the power supply to the compressor, the fuses to check, and the relay.
As far as the relay, if there is a different one in the box having the same part number, switch them. If there isn't, here is a link that explains how to test one:
In addition to checking the fuses, make sure there is power to them. Here is a link that you may find helpful:
One last link. Take a look through this and let me know if anything helps:
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
Pic 5 shows the fuse box in the vehicle and pic 6 shows the one under the hood.
See pics below.
Jul 23, 2021 at 11:01 PM
