where does the right front ABS sensor wire connect?
2007 KIA RONDO
79,000 MILES • 4.2L • 4 CYL • 2WD • AUTOMATIC
BERNIE 241
  • 5 POSTS
ABS wheel sensor.
Dec 4, 2021 at 12:03 PM
SQM
  • 6,383 POSTS
The ABS sensor plugs into the hub behind the rotor.
It is mounted by one bolt.
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
I have attached diagrams below.
Thank you.
Dec 4, 2021 at 6:52 PM
BERNIE 241
  • 5 POSTS
thank you, but i need to know where the wire end connects and where it's located.
Dec 5, 2021 at 7:06 AM
SQM
  • 6,383 POSTS
Just to clarify, the sensor is connected to the hub, but you are unable to find the where the harness plugs in to the vehicle side?
Dec 5, 2021 at 1:21 PM
BERNIE 241
  • 5 POSTS
yes that is correct.
Dec 6, 2021 at 7:36 AM
I don't know if you found the connector yet, but it is behind the inner fender/splash guard.
I attached directions below and highlighted the connection.
Let us know if this helps.
See pics below.
Dec 8, 2021 at 7:37 PM
