ABS Warning Lights Error Code - cc-id 207?
2006 BMW 325I
107,000 MILES • 2.5L • 6 CYL • 2WD • AUTOMATIC
AMAAN2121
Lights on Dash - ABS, Emergency Brake and Traction Control.
Same issue as - https://www.2carpros.com/questions/i-have-a-annoying-issue-please-help-lights-galore
Thanks.
Apr 29, 2023 at 11:42 AM
The "cc-id 207" error code on your BMW 325i is related to a fault in the ABS (Anti-lock Braking System), emergency brake, and traction control systems. Can I ask if this code was found by doing a CAN scan? If not, that is what needs to be done to find the problem exactly. because the "cc-id 207" error code is not a specific code. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a guide to help:
https://youtu.be/u-4syLc-ifQ
and
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Here is one for about $99.00 if you need it:
https://amzn.to/3ZixY4v
Please go over this guide and report back.
Apr 29, 2023 at 1:43 PM
