Working on the listed above. Getting an erratic right rear speed sensor reading, which sets a code in the ABS module. Also, getting an over speed reading from the left front wheel speed sensor, which actuates the stability control. The left front is not setting a code. In the ABS data stream, the left sensor reads fine. The right rear shows erratic. In the VSES data stream, the left front shows over speed, and the right rear shows erratic. I replaced both wheel speed sensors. Still have the same data readings. My ABS module is bad.
May 1, 2018 at 10:03 AM
