Hi there,
I have changed the 4X sensors ,and the ABS pump (used unit),but I have new problems, 1-the hand brake light,and 2-engine light stays on, 3- issue, the tachometer is not working, so don't know what happened after changing the ABS pump,
Also to reach the battery terminals is difficult in this car as it's located under the front arches of the car, very unusual place to reach it, must remove the front wheel passenger side in UK cars, and the plastic cover ,then to lose the metal frame nuts and bolts, to reach the battery, very small area for movement because of the brakes system parts on the way,you need to work side ways to get to it, so it is not easy for me to do it, I have to see the local mechanic man for it, I am getting very concerned about the cost, already has been over £ 300+ parts over£ 100,nearly lost to count the total, all that plus service costs for A MOT ticket, but I am going to gamble on a diagnostic test as last effort to solve the problem , but possibly in few weeks, as I have my work car to use, will let you know soon, later on.
Thank you for your advice.
Nov 9, 2019 at 10:49 AM
