ABS Module
2003 GMC SONOMA
169,000 MILES • 4.1L • 6 CYL • 2WD • AUTOMATIC
JIMBO66
  • 4 POSTS
Is there video on how to replace a abs module on my vehicle listed above?
Feb 3, 2017 at 8:11 PM
STEVE W.
  • 15,113 POSTS
What is the problem that makes the ABS module suspect? Code(s) There is a common problem with them that is not the module but a bad ground.
Feb 3, 2017 at 9:23 PM
JIMBO66
  • 4 POSTS
The ABS light and brake light both come on. it does not come on automatically when I crank my truck, but when I am driving it it does and does not go off.
Feb 4, 2017 at 3:24 AM
STEVE W.
  • 15,113 POSTS
The most common reason for that is a bad wheel speed sensor. You can use a good scan tool that can read ABS codes to see which one is causing the problem. If it was a failed ABS module the lights would come on as soon as you start the truck.
Feb 4, 2017 at 8:38 AM
JIMBO66
  • 4 POSTS
But it also comes on while the truck is setting still and running after it has been cranked.
Feb 4, 2017 at 10:06 AM
STEVE W.
  • 15,113 POSTS
Still more likely to be a sensor. A bad or broken wire will turn on the light as soon as the system runs a self test, which it does every time the key is turned on. That is why I suggest scanning it first. Nothing like replacing the ABS unit, then needing a scan tool to cycle it to bleed the system. Fighting to bleed the brakes and then still having a light because of a broken wire. With a scan and knowing the codes you do not just end up chasing the problem and spending time and money on unneeded parts.
Feb 4, 2017 at 11:27 AM
JIMBO66
  • 4 POSTS
How do you scan it and how do I get a tool to do that with?
Feb 4, 2017 at 12:18 PM
STEVE W.
  • 15,113 POSTS
You need a scan tool that can read ABS codes. Most of the parts stores will only scan for engine/power-train codes. My suggestion is to buy an entry level tool and use it. Having it yourself means that you can also help friends/neighbors or even family as well. Plus it would allow you to actually see what the codes are and possibly some of the live data to make servicing a vehicle easier.
These are just some examples of tools that can read OBDII/CAN/ABS and more.
Innova 3150e
Cen-Tech® - #60794
Craftsman #568590
Actron CP9580A
Actron CP9690
Feb 5, 2017 at 1:18 PM
