After hitting the brakes hard, the dashboard lit up, ABS, Skid control, (!) Brake all lit up, brakes felt like manual brakes, could it be the ABS Module needs replacing?
2007 TOYOTA HIGHLANDER HYBRID
280,000 MILES • 3.3L • 6 CYL • 4WD • AUTOMATIC
PBUONOMO
  • 7 POSTS
I was missing a left turn, nobody was behind me and I hit the brakes a little hard to make the turn. Dashboard lit up. ABS, Skid control, (!) Brake all lit up.... brakes felt like manual brakes... loud tone went off, this tone stayed on and is still on....and it felt like brakes were partly on when I was limping home.... got home front brakes hot...
I removed relays for ABS Motor and brakes let up so I could at least drive locally. (I know I shouldn't have but needed to get to auto store...
I did a scan and found it's the ABS module...as all my hydraulic pressures were low in all 4 wheels..., also the motor of the ABS kept ticking...tic, tic tic... stopped after relays pulled...
Since I have 280,000 miles, I didn't want to buy a new unit, so I bought a used one with 30-day return policy....
Installed the unit with exact same model number 44510-48060. worked for few minutes...but all lights stayed on...thought I'd just need to clear codes...(which I didn't do yet as I did the codes at autocrats store and they said they can't clear codes..etc..)
Bleed the brakes thought that would help but it didn't.... ABS stopped working as brakes went to "Manual again"........Bought Innova code reader that does ABS reading/clearing...I hope tonight this does the trick??? Worried it won't.. I will clear the codes and see what happens..
made appt. at Toyota to "RE-Program" ABS module...but not sure if it's worth the $180? Do you think this will make the module start working?
What do you think?
I will clear the cords and see if lights come back on? If they come back on, could it be the used ABS module may be defective?
Sorry for all the questions...not sure what to do??
Thank you very much for any help
Pete B.
Jun 15, 2023 at 2:34 PM
PBUONOMO
  • 7 POSTS
Hi Guys,
This is Pete, I cleared the codes. All the lights went off. Brakes back to normal...All working....Thanks for your site... I was about to pull my hair out!
Jun 15, 2023 at 7:13 PM
Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Jun 16, 2023 at 8:42 AM
