Sorry. I forgot that this was a year that they started using a relutor ring with a magnetic encoding ring.
Take a look below at these pictures. However, you do not need to replace the entire axle. There are many options out there for repair kits.
However, I am also attaching a case as well for this issue. If the axle nut is loose then it will cause this code. So, I would suggest checking this and making sure this is not the issue.
Please let us know what happens. Thanks
Nov 3, 2021 at 6:46 PM
