First, this vehicle isn't offered in the US, but I will try my best to help.
most commonly, the ABS light will come on when a wheel speed sensor fails. Have they been checked? That is where I would start. Also, before the module was removed and sent for repair, diagnostic trouble codes should have been checked. That could have indicated if it was a sensor or other component.
At this point, I would suggest checking wheel speed sensors. It can be done with a live data scanner or manually. Here is a link that shows how it is done:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
I would also like to point out that most vehicles' abs modules are fused, so check for a blown fuse as well.
Let me know what you find.
Feb 13, 2020 at 6:25 PM
