abs light on , steering wheel sensor, traction sensor
2004 PONTIAC GRAND PRIX
131,000 MILES
RWARD47
  • 4 POSTS
my can does not code, but these lights are on could it be poor brakes or a loose or bad wire or sensor on the wheel hub. abs light on, steering wheel sensor and traction sensor what can be done to fix this problem.
May 19, 2013 at 5:48 PM
we need the code for the abs. when that is repaired, the trac will come back on line
if the light is on, then there is a code
May 19, 2013 at 5:58 PM
RWARD47
  • 4 POSTS
It did not code on my obd scanner no codes found
May 19, 2013 at 6:18 PM
your code reader may not read abs codes. if the light is on, there is a code
roy
May 19, 2013 at 6:33 PM
