ABS light on and off, ABS is activating while turning with no brake pedal depressed.
1998 GMC SONOMA
140,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
GREGDILLON1973
I have been chasing this problem for a while, when turning without the brake pedal applied the ABS will activate and then when you try to stop the vehicle it is impossible due to the ABS being activated. I had a Check Engine light on today and the shop told me I had several codes, one being faulty brake light switch. Would this be causing the issue I am having?
May 29, 2015 at 10:45 AM
HMAC300
  • 48,601 POSTS
you really know what codes are being sent to properly diagnose this. however if they told you switch is bad replace it. but it will need a scanner to get rid of all the codes to start over. also check battery for condition including load test as that can give false codes as well.
May 29, 2015 at 12:06 PM
