ABS light on
2002 GMC SIERRA
280,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
JASONPYZO
  • 87 POSTS
it is my buddies truck and the ABS light is on he took it to auto zone and told him it needs a brake module. I looked at it and the system is not like the one on my truck, it does not have a brake boost and it looks like it runs of the power steering pump. it also has a problem of rear brakes lock up when applied hard, the inside of the rear rotors are cut in pretty bad also. Would that have to do with the brake module also and is this something I would be able to do? Because I did some research and they are saying I would need a Tech II to allow the ABS system to go through a bleed process if I replace the calipers and also to power bleed the system? We are also putting all new suspension and steering components and hubs on the front.
Mar 3, 2017 at 9:41 PM
HMAC300
  • 48,601 POSTS
sometimes you can get away with bleeding brakes on these with a power bleeder. however an ABS unit needs to be programmed to the vehicle which you cannot do a mechanic can and he can scan for codes as well as auto parts most do not know what causes what and are not very good diagnosticians. best to have a real mechanic check it with his scanner. by the way you have a hydraulic booster on this vehicle not vacuum operated.
Mar 4, 2017 at 7:57 AM
JASONPYZO
  • 87 POSTS
okay, thanks.
Mar 4, 2017 at 10:34 PM
SATURNTECH9
  • 30,869 POSTS
When you open up the hydraulic system on the if it requires a scan tool to bleed the brakes. If you just try to bleed the brakes you will never get a good pedal. So you would have to have to have it towed to a place that can bleed the brakes with a scan tool. The scan tool runs the ABS pump first then you bleed the brakes normally. A pressure bleeder cannot take the place of running the ABS pump with a scan tool. What was the exact code number it had not code description?
Mar 5, 2017 at 12:37 AM
JASONPYZO
  • 87 POSTS
not sure I would have to ask him?
Mar 5, 2017 at 7:31 PM
SATURNTECH9
  • 30,869 POSTS
Yeah, if you do not remember it.
Mar 5, 2017 at 7:42 PM
JASONPYZO
  • 87 POSTS
I never knew it, I was going on what he said and did. Just was wondering how difficult it would be to work on.
Mar 5, 2017 at 7:49 PM
SATURNTECH9
  • 30,869 POSTS
With what auto zone said it needs a ABS module they only read codes and sell parts there not mechanics.
Mar 5, 2017 at 7:58 PM
JASONPYZO
  • 87 POSTS
I hear ya.
Mar 5, 2017 at 8:00 PM
SATURNTECH9
  • 30,869 POSTS
So that is why I asked what the code was. also, does the ABS light come on as soon as you start driving?
Mar 5, 2017 at 8:10 PM
JASONPYZO
  • 87 POSTS
I believe it stays on.
Mar 5, 2017 at 10:58 PM
SATURNTECH9
  • 30,869 POSTS
If I had the actual code number the letter followed by the four digit code I could tell you more. You might need a professional scan tool that can read live data from the ABS computer to actually diagnose the issue. But let's start with the code.
Mar 6, 2017 at 6:58 AM
JASONPYZO
  • 87 POSTS
alright
Mar 6, 2017 at 8:55 PM
Please let us know what you find so it will help others.
Best, Ken
Mar 9, 2017 at 8:53 AM
JASONPYZO
  • 87 POSTS
I was doing a lift on my buddies truck and while we were in there we ended up replacing the entire front suspension and steering linkage. The light ended up going off so it might have been one of the speed sensors on the one of the hubs, I still think the brake system can use some work because I think the brake pedal doesn't feel as good as it could. But he's happy but I told him to keep an eye one it. I appreciate all the help, Thanks
Mar 9, 2017 at 8:46 PM
Good to hear, please use 2CarPros anytime we are here to help.
Best, Ken
Mar 10, 2017 at 10:34 AM
