ABS light on
2004 NISSAN FRONTIER
160,000 MILES • 3.3L • V6 • 4WD • AUTOMATIC
CHASE156
  • 37 POSTS
Checked resistance values at both connectors and main plug where it installs in module, resistance reads 960 ohms. I checked for shorted wire none, both left and right sides front read the same. I tried spinning the wheel but I could not get it to go fast enough. Any help would be appreciated. Thank you
Feb 21, 2018 at 9:56 AM
Good afternoon.
Did you check the rears as well?
When you spin the wheel, check for any AC voltage on your meter.
there are other possible failures other than the sensors. Do you have a scan tool to read the fault code?
Feb 21, 2018 at 11:56 AM
CHASE156
  • 37 POSTS
Thanks for your reply Roy,still have to check the rear sensors,I ordered a new ob2 with abs and srs schould be getting it by Monday,I will keep in touch,thanks
Feb 21, 2018 at 2:33 PM
Sounds like a plan. Will be waiting for the information.
Feb 22, 2018 at 1:20 AM
CHASE156
  • 37 POSTS
Hello Roy, I did not receive my scanner yet, but I checked all the ABS sensors again. left front 1069, right front,1059, left rear 1061, right rear,1059. Henry (the only repair I made I soldered the left front and right front cables and these are the resistance readings).
Feb 22, 2018 at 8:51 AM
CHASE156
  • 37 POSTS
Readings were taken at connector at ABS module.
Feb 22, 2018 at 8:55 AM
Okay, then you need to read the code and let me know what it is so we can proceed.
Feb 22, 2018 at 9:01 AM
CHASE156
  • 37 POSTS
Okay, thanks.
Feb 22, 2018 at 2:24 PM
Get back to me with the codes and we can continue.
Feb 22, 2018 at 2:30 PM
CHASE156
  • 37 POSTS
As soon as I get my scanner, hopefully by next week.
Feb 22, 2018 at 2:45 PM
sounds like a plan.
Feb 22, 2018 at 2:51 PM
CHASE156
  • 37 POSTS
Hello Roy after all this time I waited for the scanner, it turned out to be defective. now I have to return it and buy another one. sorry for the delay. Henry
Mar 2, 2018 at 9:01 AM
No problem. We are here when you are ready.
Mar 2, 2018 at 9:29 AM
CHASE156
  • 37 POSTS
Hello Roy, we spoke about this issue prior and I did receive my scanner. I had to install the software in the autel ml619. I am confused now at one point the scanner says control 1 and then it says cannot connect and battery may not be charged and check connection. the techs are not in today because of bad weather. what is your opinion about control 1? Thanks, Henry
Mar 3, 2018 at 2:45 PM (Merged)
CARADIODOC
  • 34,306 POSTS
If you are continuing a previous conversation, you need to reply to the link you got in the automated e-mails. No one else knows what is going on or the previous history. If you cannot find your way back to your original post, reply back here with the user name of who you were working with and I will see if I can get the two of you back together.
Hi again.
What model did you get and I will see if I can get some info
Mar 3, 2018 at 3:31 PM
CHASE156
  • 37 POSTS
That is okay have to research another model scanner, this was an Autel Al619 that could not communicate when I plugged it in.
Mar 3, 2018 at 3:34 PM
CHASE156
  • 37 POSTS
Hello Roy, just wanted to update you. this is my third scanner I had to return because it was unable to read the ABS on a four wheel drive truck. Innova 3140g. before I ordered these obd2 readers I called the companies up to confirm it will read a four wheel drive
and now I just called up Innova and they said they have no obd2 that can read four wheel drive. I now have to research another one, really sickening these people do not know what they are talking about. Henry
Mar 8, 2018 at 2:09 PM (Merged)
CHASE156
  • 37 POSTS
Hello Roy, I wanted to update you,I decided to bring my truck to two repair shops,they had snap testers, when they plugged in the connector both shops came up with the same message, could not communicate. one shop tried grounding one terminal and he said he could not get the ABS light to even flash. any suggestions? Thanks, Henry
Mar 9, 2018 at 12:05 PM (Merged)
CHASE156
  • 37 POSTS
Roy he did manage to communicate with the engine but not the ABS.
Mar 9, 2018 at 12:07 PM (Merged)
Good afternoon.
Okay, is the scan tool he is using able to monitor the ABS? Some scan tools do not have that availability.
CHASE156
  • 37 POSTS
Yes.
Okay, he needs to verify powers and grounds to the ABS module. if he has these then the module is the issue. it is not allowing anything to access it.
CHASE156
  • 37 POSTS
Hello Roy,I found a diagram of the t39 connector that goes to the abs module,I checked pin 44 to ground and it only has 7.5 volts,the wire is a solid blue with a white stripe,I just have to find out where the other end is,any suggestions,thanks Henry(sorry to bother you)
Mar 12, 2018 at 11:21 AM (Merged)
Hi, you never bother me.
Let me get a diagram for you
Three powers to the module. check for battery voltage to all three pins.
CHASE156
  • 37 POSTS
Hello Roy,seems as though it is the ABS module. I have all three voltages there,I have to see what I am going to do now. Thanks
okay.
If you replace with a used one, it will have to be flashed to your truck.
CHASE156
  • 37 POSTS
Hello Roy,
I am assuming the abs actuator has a high psi stored,if so how would I bleed off that high pressure?
Mar 13, 2018 at 5:32 PM (Merged)
MHPAUTOS
  • 31,937 POSTS
Only line pressure here, ABS has an internal pump,that activates when the system is required, what is the actual problem you have?
CHASE156
  • 37 POSTS
Thanks for your reply,I thought even when the truck was off it still had a high psi stored.
Mar 14, 2018 at 1:26 PM (Merged)
MHPAUTOS
  • 31,937 POSTS
there should be no pressure in the system, just take normal precautions when opening any hydraulic system.
CHASE156
  • 37 POSTS
Hello Roy,
I wanted to update you on this issue. I located and bought a used module and installed, (I did not flash the module). still the same issue, light will not go out. I bought the Bluedriver OBD2 and it says no pending ABS codes. I tried clearing the light with this unit still no good.
Do you know where pin 44 connects to? I figured I would track that down to another connector because it only has 7.4 volts. any other suggestions? thanks, Henry
Apr 6, 2018 at 10:20 AM (Merged)
Good morning.
Let me check.
Apr 6, 2018 at 10:36 AM
Goes to the ABS light in the cluster.
The light may be on from the flash not being done as well.
Apr 6, 2018 at 10:42 AM
