ABS light is on, but ABS is working
2010 HYUNDAI GETZ
144,000 MILES • 1.6L • AUTOMATIC
SORA123
  • 4 POSTS
Hi everyone,
I recently purchased the car listed above. It has been maintained very well and the previous owner has a very transparent clear service history information. After the previous owner took it for the last service before completing the purchase with me, the Abs light came on. It appeared to be an easy fix, but he ended up spending a lot of money getting a Hyundai mechanic to look at it. They connected the scanner to the car but the Hyundai something was ‘offline’ at the time so they couldn’t get a proper reading. Upon further testing they found out that actually the ABS sensors, and the ABS itself was working. He showed me the videos of it being tested on the computer while it was being driven. He continued to look for a fix through the mechanics, but the mechanics had already spent a lot of time and money looking into it and still couldn’t find the cause. He didn’t want to spend any more time on it as his wife recently had a baby and he started running a business; so, he offered to drop $1,000 off the price or he would readvertise it and then sell it; I ended up purchasing it. He thought the cause may have been the cluster/instrument board as he recalls that one day when he was opening that up to replace the cluster board lights, he heard an odd sound when he was opening/closing the cluster/instrument board.
Does anyone have insight on the cause for this? I also don’t want to spend any unnecessary time and money on this, but I do want to get the ABS light turned off to put my mind at ease.
Jun 5, 2022 at 9:10 PM
We can fix it, no problem. What is the code the system has? This guide/video will show you how to get the codes, it sounds like a bearing hub might be out which can cause a difficult problem to find.
https://youtu.be/rTtAnsOlZU4
Let us know what happens and please upload pictures or videos of the problem. I can tell for sure what's wrong if we have the code number.
Jun 6, 2022 at 7:13 PM
SORA123
  • 4 POSTS
That’s the issue. No codes show up when it is scanned. This is what happened when the previous owner took it to a Hyundai mechanic. So, they checked the fuses, sensors etc., and they were all working.
Jun 7, 2022 at 7:23 PM
This only leaves the ASB controller being bad. Here is how you can change it out with a new unit in the diagrams below. Check out the diagrams (below). Please let us know what you find.
Jun 8, 2022 at 12:12 PM
SORA123
  • 4 POSTS
Thanks.
So even though the ABS was tested recently while it was being driven with a scanner connected to it, and it was working, it is still the ABS controller which is bad that is showing the ABS light? This is the part I am confused about.
If I was able to source the correct part, how much would you charge for the labor of replacing it?
Jun 9, 2022 at 6:36 AM
Yes, the controller is giving you an error even though there is none, so the warning portion of the controller is bad, the labor time to change it out is .6 hours.
Jun 10, 2022 at 9:08 AM
