Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Mercedes Benz
C230
Warning Lights
ABS Light
ABS light turned on after replacing front brake pads
1999 MERCEDES BENZ C230
101,400 MILES • 2.3L • 4 CYL • TURBO • 2WD • AUTOMATIC
ROYALGEM2023
MEMBER
1 POST
FOLLOW
Then when I start the engine next time the ABS is not on. Also after replaced the front pads the brake pedal goes half way to the floor.
Sep 10, 2020 at 5:09 AM
CERTIFIED EXPERT
Good morning,
Check the sensors for the front wheels to be sure there is no loose connections or damage to the ABS sensor.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Can you get me the code that is stored for the light to narrow the area of failure?
Did you replace the rotors as well? This could be the result of the pedal. Mercedes always recommends pads, rotors and sensors for a brake reline.
Did you bleed the brakes when you were finished?
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Sep 10, 2020 at 5:16 AM
